CoronaRaptor
1 1/16thI welded a bolt head to a nut, not sure if it was an exact 27mm but close enough, something like a 7/8" or 1" bolt (so 20mm or 22mm diameter bolt maybe?)...
OP, I would just remove that lower steering shaft with the swivels on it and when it is off, check for looseness, especially in the lower joint, seems to be the common culprit.
2010 FORD F-150 6.2L V8 Steering Shaft | Shop Now at RockAuto
Steering Parts and More for Your 2010 FORD F-150 at Reliably Low Prices. Fast Online Catalog. DIY-Easy. Your Choice of Quality. Full Manufacturer Warranty.
www.rockauto.com
