banman12
Because... don't know if anyone else here that has Toyo M/T's is experiencing what I am, a pull to the right. After some research it seems it is a common issue with the Toyo's due to their aggressive tread. I had my alignment checked and everything is good, and even put my stock wheels and tires back on. No pull with the stocks. I also rotated the Toyo's around, but made no difference. A lot of people run steering stabilizers to offset the pull, not on Raptors, but in general. Now, I realize I can get have my camber/caster adjusted to compensate for the pull, but then onec the stocks go back on in the winter months it's going to pull left, so that is out of the question. I also read that this pull tends to get better or even disappear after a few thousand miles. Hopefully this is true. I only have a little over a thousand miles on them now. Will have to wait and see i guess.
