Txfight00
Dang. Sounds no bueno for me then. Thanks for the input fellas, I'll keep this updated. Worst case, Mil T posted on a shop here in Phx that does rack rebuilds. May have to go that route.
DAMN! You guys are making me not want to install my SDHQ tie rods now.
I don't want all these headaches.
(stock rack and tie rods) I am having the same issue I have a rattling noise on my drivers side only when offroad that I have pin pointed to my rack with only 5300 miles. First dealer blames it on the sb about shock noise I call bs! I am a master certified shop foreman and have double checked all fasteners on the front end myself before taking it to the dealer. I showed the foreman at the dealer the play and made the noise and he says it is normal play but when we went to a new 2014 and I grabbed the tie rod it had very little play and no noise at all. I will be taking it to a diff dealer and show them the noise and excessive play that is present when I grab the drivers side tie rod and shake it.
This may be a little bit of an old thread but was wondering if you ever got this resolved through your dealer. I am having the exact same issues(excessive play and rattle on the drivers side) I actually had the drivers side tie rod replace under warranty because I thought that was where the noise was coming from but when I got home I noticed that they didn't put a clamp on the inner tierod boot and also noticed the shaft that goes into the rack was what was moving and making all the noise. I took it back up and they said the play is "within specs" and is normal. I just can't buy that.
