Spec-D LED tails installed, love them!
Fred
Richmond, VA
Any mounting issues with the resistors? Do resistors come with the tails?
Icecobra
Gilroy Garlic capital of the world
Thanks, those are the clear black.. Resistors came with two one for each side Easy to mount they have a clear two sided bonding material I would not call tape... They lined up and plugged in perfectly.. I would go slow and check and recheck as you slide them in to place... There not the exact fit like the factory fit but pretty dam close and other than I get picky about how things fit they look good installed... And thanks for the graphics comments....
HAP
NE NC
Ice, did you have 2 connectors (yellow & black wire) on each light for the resistor? If so, which plug did you use, upper or lower?
HAP
Fastcote
Powell, OH
HAP
I'm pretty sure you have to use BOTH upper and lower. I did at least and no hyperflash.
RatedSVT
Sleepy Hollow,IL
I guess I was under the impression that everyone saw the pic's posted on the Red Raptor when we first heard of them. That's what made me decide to order...
exactly, that was on a red raptor. I have a blue flame and would like to see how they look next to the blue paint. :)
Icecobra
I had two load resistors one for each side and two yellow black connectors on each tail light so I installed it to the upper one since this places a load I figure since both are parallel it does not matter which one you use. This should work as it puts the load on the circuit. That's the best answer I have and looked all over for directions to suggest otherwise..
HAP
NE NC
Got Hyperflash! So, how did you connect both connectors to the one plug of the resistor? Also, it did not matter if you use upper or lower alone, still hyperflashed. At least on the 2014.
