Spark plug swap and new plug wires....
Sandfreak520
Washington State
Hey guys I’m about to tackle the plugs and put new wires in my 2012 screw it just hit 98k and I think it’s time.... checking to see if anyone has done there own and if they had any issues or advice only cause I’ve heard horror stories of some in the back breaking or getting snapped if not careful...? Also has anyone had any experience or feedback on the granateli plug wires an 0hm pucks upgrade......? Thanks in advance for all your help!
allinon72
Indianapolis, IN
If you do a search there are several threads, including some tailored to helpful hints. I replaced my own plugs and didn't find it all that difficult, but it is time consuming due to the sheer amount of plugs. Only 1 of the plugs really give an issue, the one behind the p/s shock tower. However, everyone's tolerance for DIY will be different based on skill level. Wires are simple.
Sandfreak520
Sandfreak520
Washington State
Will do thanks I’m sure it will be a breeze an have heard that the one you had slightly harder time with is typical so I’ll wait for a free weekend borrow buddies lift and that should also help the process figure plugs won’t hurt might as well change them too thx
R
Rick@FreedomMotorsports
Guest
We sell the Granatelli wires and NGK plugs as a kit. We have probably sold over 50 kits so far this year. We had one person say they had interference on FM and we replaced all the wires for him to solve the issue. Think maybe one of the wires was damaged or faulty but it was quicker to send him out a new set as that was a better way to handle for customer service wise instead of having him try to determine what wire might of been causing the issue.
If you want to get a kit, you can go here:
https://www.freedommotorsports.us/c...ive-train-engine-performance-maintenance.html
FRF Members can use promo code: FRFMAINTENANCE11
Thanks!
Rick
SS308
Cheyenne, Wyoming
If you do decide to replace the plugs, be careful not to break one off.
If you do, the fun really begins...
A friend of a friend had this unfortunate experience... ;)
Sandfreak520
Sandfreak520
Washington State
Thanks yea that’s my only issue/ concern during the swap I do NOT want to hear that snap sound ! Only had it once before on an old dirt bike just that one plug was a pain int the arse to fix and make work don’t wanna mess with that on the raptor!!
Ricoman
WASHINGTON STATE
I'm about to tackle the same job....and taking advice from some of the other members I bought these 2 "tool" items...
GEARWRENCH 3/8" Drive 84 Tooth Offset Flex Head Teardrop Ratchet 11" - 81214F
GearWrench Tools KDT41740 Magnetic Universal Spark Plug Service Kit, 5/8-Inch, 3 Piece
Figured for $70 it might save me some headaches...
It was also suggested to buy a set of : NGK58976
Ignition : Spark Plug / Coil-On-Plug Boot
They are around $50 on RockAuto,(only need 8,not 16 like plugs,)and since you have to deal with them anyway,might as well change...and IF you break one off while changing the plugs,your dead in the water until you can get a new one...cheap insurance in my eyes...Once I'm under the hood and committed to the job,I'm going for plugs,wires,boots...everything except the actual coils which are really pricey and look like they would be easy to change later.
Ricoman
WASHINGTON STATE
Where you at in WA..? I'll change yours if you change mine...;)
