Sp 542
Higgs Boson
Texas Hill Country
the 542s may be different from 2017 plugs but they were identical to my 2018 plugs, which were also not the plugs the threads stated were in the truck stock.
i think ford made a change from 17 to 18. i do agree with the benefits of a colder plug when needed, but in my experience with my truck, the 542s will not benefit.
i measure spark advance and retard, knock, etc etc and they provided no benefit. my truck has adapters, downpipes, tune, etc.
placebo, at least for an 18, I can't speak for a 17.
RaptorFlipper
The Woodlands, Tx
That is interesting Higgs. There are quite few guys on here who swear by them. My mechanic thought they were better as well. I am only saying what he said about them. Maybe Ford did make a switch this year. Let me go see what was in mine stock.
Onemoosehorn
Sp 542’s made a big difference in my 18 as far as idling. Little better pull throughout boost also. I can tell a difference. But my 18 also had SP 527’s from factory, according to the part number, for some reason.
TXRaptor
Yes,
I am trying to find out what mine had from Ford. I replaced immediately. Ill keep you posted.
My 2018 had the following plugs:
CYFS12PCT
I swapped them at 2000 miles. I was not having any of the problems others reported, but I wanted to avoid issues.
Where do you find the translation from the part on the plug to the type?
B
bo1966
Just like changing the oil so early. There is no point to it.
Change your oil when you want. I'll do the same[COLOR="Red"[COLOR="Red"]
---------- Post added at 09:34 PM ---------- Previous post was at 09:33 PM ----------[/SIZE
---------- Post added at 09:37 PM ---------- Previous post was at 09:34 PM ----------
Thank you for explaining it. It is appreciated. Also, thank you for not just making comments that don't address or answer the original questions
Onemoosehorn
CYFS12PCT
I just did a search online for the part number. A dealer I called had no idea the “SP” equivalent for the part number. I believe that’s the same plug I had. That number was the 527, from what I could find. I could be wrong though.
NASSTY
ME
CYFS12PCT
My 2017 came with CYFS-12Y-PCT. I replaced them with SP 550 which also have part# CYFS-12Y-PCT on them. I ran the part# for the hell of it and that # comes up as SP 550 and also says Superseded Part Number SP-527. So it appears that SP 550 and SP 527 are the same.
Onemoosehorn
Thanks.
RaptorFlipper
The Woodlands, Tx
Ok. My 18 came with Motorcraft SP534 or CYFS-12Y-T3. I replaced with higher boost plug SP542 OR CYFS-092-YPT. Pre-gapped at 025-030. I simply went with what my guy suggested. All he does is work on race cars and trucks. The truck runs awesome! Hope this info helps.
