- Joined
- Dec 16, 2016
- Posts
- 17,689
- Reaction score
- 27,295
In a similar way to how you would adjust tire pressure on a track car with decent tires, slicks, etc. This is going to vary day to day, track to track, but usually within a specific range. As an example I know the pirellis on my zx10r want about 33-35 front, 32-34 rear on the street accounting for pot holes, etc. On the track I can go 1-1.5 psi lower safely at a moderately fast pace, to high 20’s if I don’t care about tire life beyond the day.
You need to think about the core driving you’re going to be doing on and off road and establish base line as mentioned above. Washboard roads are going to give you fits at 36 psi and up. Honestly you probably want closer to 32 psi.
Sure, if you’re hauling a cr@p ton of stuff in the bed and 75-80 mph for long trips, crank that psi up, but if you’re just commuting and hitting up some occasional dirt/gravel and light off roading, consider setting lower to get to your base line or a compromise where your street manners are still ok but you’ve significantly improved compliance off road. This isn’t a corner carver, so don’t try and make it one as you’re lowering the psi to get to your truck’s happy place. The KO2’s have flexible sidewalls, to get off road compliance. If you maintain the door sill 38 psi, you’re going to be bouncing quite a bit.
