SnoBall Preparations?
SilentShooter
Siesta Key, FL
Those thinking of running KC Cyclones thru the back window and have Dark Tint might want to reconsider.
I tested it on my truck tonight both inside and out. I set my phone to ISO 400 so it would show the difference properly.
As you can see in the pic with the running lights and the KC in the window the running lights appear brighter than the KC.
Then you have it inside with no running lights and lastly the pic with the KC outside the window where it is much brighter.
BramageDained
Did the totally arduous task of moving my spare to the bed, where it sits all winter anyway, which completes everything for my truck.
I think I'm just going to leave my rear light how it is, unless I can maybe find something stick-on to diffuse the light.
My front light bar is tinted blue again, which I actually did a couple weeks ago.
BramageDained
Dad's bubba rope, radio, and shackles came in the mail. I got his radio programmed with the SnoBall channels and reprogrammed mine since apparently I had Tx power limited when I did mine the first time(which was before SnoBall #1).
He has his spare and recovery kit in the bed of the truck now similar to mine.
His rear light should be fabbed this week then just waiting for his order from Olympus.
We're both looking at RallyArmour mudflaps.
SilentShooter
Siesta Key, FL
Received my HDS mount, and was wondering anyone have issue with the center channel speaker being so close to the unit?
I just wired mine up to a 12v lighter socket real quick to test and it seemed to be having a hard time getting a fix. Was not sure if anyone else was having trouble and if going with an external antenna is the best solution.
rap67
SE michigan and Arkansas
Received my HDS mount, and was wondering anyone have issue with the center channel speaker being so close to the unit? I just wired mine up to a 12v lighter socket real quick to test and it seemed to be having a hard time getting a fix. Was not sure if anyone else was having trouble and if going with an external antenna is the best solution.
No issue with the speaker. But I had reception issues. I went with the remote receiver and it cleared it up.
