Underside protection is one area that is often overlooked. If you're heading beyond the Starbuck's parking lot with your truck, upgraded skid plates are something to seriously consider. Crown Offroad and RCI MetalWorks have worked together over the last few years to offer you some of the best under carriage armor available. If you are using your truck for running over the neighborhood Prius, bombing through the desert or traversing the mountains, RCI skid plates are the best defense for all on and off-road hazards.
Crown Offroad has run a full set of RCI skids on our shop truck for years and they held up to some serious torture. We recommend RCI’s entire line of skid plates for front end, the transmission, transfer case and fuel tank. After removing the stock skids and comparing them, these are hands down a YUGE improvement in protecting your truck's vital components.
Link ------->>>> CROWN OFFROAD
• Protects expensive power steering unit, front differential, front cross-member, engine, engine bay, transmission, fuel tank, etc
• Compatible with all 09-14 F150/Raptor models (2017 Raptor fitment TBD)
• Front skid plate mounts directly to frame horns behind tow hooks and is compatible with most aftermarket bumpers, hidden winch, etc.
• Smooth, flat surface that easily slides over obstacles
• Heavy duty black powder coat standard on steel options and optional for aluminum skids
• Installs in minutes with basic hand tools
• All hardware and installation instructions provided
• Direct bolt on addition to existing factory attachment points no drilling required
• Designed and built in the USA!
