Low nitrogen PSI in rebuilds
I invested $310 in this nitrogen tank and regulator setup with no loss chuck to check the shock pressure of the forged off-road rebuilds installed 6,000 miles ago. The left rear shock was 152 psi, the right rear shock at 128, the left front at 122, the right front at 130. I set them all at 210 for now.
From what I could tell from related posts and youtube videos, Fox shocks should run between 200-240 psi. What I found on my shocks were the schrader valves were not tight and don't appear to have any thread locker or sealer, I tightened them gently so as not to strip them.
When I removed the no loss chuck from the first shock, the shrader valve started backing out resulting in loss of some nitrogen, so had to redo that shock. All were not tight/seated, so I suspect some nitrogen seepage from where the schraders screw into the shock.
Recommend checking your schrader valves are properly tightened if you have them, be careful not to over tighten/strip the threads.
