Shock coating
Mluis11
What do you guys recommend coating shocks with after sanding off rust spots?
Mluis11
Mluis11
What shocks?
Mluis11
Mluis11
@Mluis11 I used just Jetsal and wax on them but will coat them with Fluid film for winter. I've used wax on polished aluminum parts before and those have held winter well. Never had any oxidation on them, so i thought it would best to coat shocks too with wax.
Sounds good. Thx for the info
MTF
Celebration, Florida
You should spray up those leafs with a Wire Rope Cable, Open Gear and Chain Lube spray!!!
It will get rid of the rusting!!! Too.
It will also bring life back to them for better ride comfort, right now there are practically binding with no lubrication.
Let the rear go to full droop to open the springs up and spray away.
