1BAD454SSv2
Theories on Rods breaking from what I have read over the years. Connecting rods are very strong under a compressive load. Compression and power stroke rods will rarely break even under a good amount of boost. Unless your detonating then all bets are off . Detonation pressures are very extreme and rods pistons will not last long .
The common point in cycle rods break is at the point of pushing the exhaust out and drawing in the intake charge . So the piston is causing a lot of tensile force on rod and it pulls rod apart. The higher the rpm more tensile force starts becoming exponentially high.
Think about it. your doing a hard boost pull and end of a run you snap the throttle closed and decelerate . You just went from boost to a high vacuum in an instant. Most engines blow at end of the track when they let out.
I have changed my driving style for quite a few years now . I tend to roll into the throttle and roll out of it . No sudden throttle changes if I can help it. When I was was doing my dragy runs in my Gen 2 I had enough road at the end to ease out of throttle and slow down . Made sure oil was full and over 200 deg . Stuff just breaks
