Sasquatch77
Banned
- Joined
- Feb 25, 2016
- Posts
- 825
- Reaction score
- 164
Google ecoboost weep hole and you will find the plethora of stickies with the multitude of threads proving this. I am sorry if you have trouble googling this.
That is exactly what he is trying to accomplish.k-rub said:A Google search with these keywords will probably make this issue seem way worse than it actually is.
Hey numb nuts.... those links have nothing to do with 2015+ Ecoboosts.... so stop trolling.![]()
You have been here long enough to know that there are 2017s misfiring here. You can't deny that - several posts with the same problem. One, of which did the weep hole and problem solved. Explain that...
I've read about one guy that drilled the weep hole..not knowing if that was the issue or not. Another guy that had a misfire had the misfire go away after the dealer changed a spark plug.
Exactly right. What caused that misfire and the plug to go bad? Only one thing does that and it has been proven over time to be condensate. You guys are on the same learning curve as the gen 1 ecoboost crowd was. I am trying to help. Heck... even Full Race knows there is a condensate issue that is the root cause of problems.
Can you explain why so many have had this misfire? All of mine had it and that's why I unloaded them. I don't know anyone who has had a good ecoboost experience, and that includes the different Ford Service people I run in to.
