SDHQ ABS Guards
Eagle Keeper
I ordered a set of the ABS guards and I thought I would post a few pictures of them. The overall quality of them is exceptional. I really like that they made a specific one for each corner. I will add installed pictures as time allows.:thumpsup2:
BigJ
Very cool!
What are the white strips (pads?) on each?
NoCaDiver
Are these the same things that J just installed on his truck but from a different manufacturer? If not, where do they go? I know his were for wheel/speed sensors, but are people having this many problems while offroading with their Raptors that they need these extra tid-bit add-ons?
SDHQ
GILBERT, AZ
Right on! Glad you like them.. Here's to hoping you find time for install!!
SDHQ
GILBERT, AZ
Different mfg... SDHQ... The main protection points are for the rear abs/speed sensors (those will cost you $$ if broken) the front are to help keep the vacuum lines front being popped off from debris
http://www.superduty-hq.com/fordraptorabsguards.aspx
Eagle Keeper
Eagle Keeper
Well I finally found the time to get the ABS gaurds installed. It is a very easy process and would have taken me less than 30 minutes but I had to retake some of the pictures!! I took all the pictures from the front side of the axles. Let me know if you want to see any additional pictures.
Right rear before:
Right rear after:
Right front before:
Right front after:
Left rear before:
Left rear after:
Left front before (I took the bolt out before I took the picture):
Left front after:
