Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Does anyone have a good solution or have you experienced a sagging door panel? I've not came up with a good solution that's holding at this point. Would like some ideas/solutions for those that have dealt with this issue short of buying a new panel.
solution 2. pull the window switch. use a heat gun (very carefully) and contact cement on the rubber. mold it back over into its original spot and let the glue set.
