Ryan's 2020 Build
Pacific Wheel
Reno, NV
Got the KO2’s mounted up to the Methods. Reasonably happy with the look. Might change out the ring bolts to black. The black Method lugs and black center cap from Chief Machining will probably make me happy.
Clearly some work ahead to make them fit!
The guys over at Chief Machining are awesome but just a heads up. Their caps don't work with the MR315's since they are hub centric (87mm). However if you open the center bore to 94mm on MR315 you'll be be good.
ryan505
ryan505
Denver, CO
Yep I realized this a couple days ago. Debating what I want to do now. Might have some sweet caps for sale for cheap :)
Pacific Wheel
Reno, NV
Chief Machining will make you some custom bolt on caps though. A little more money but some low profile billet caps with some custom engraving would be pretty slick.
Rednose
Dubai
First official project done! Bumper and light bar.
Nice build and parts I love the bolt on bumper and heads up, the skid plat is thin and will definitely bend with a strong hit I changed mine to an 8 mm plate to take the abuse. I know we all don't drive the same way but I just wanted to share my experience in case you needed it and good luck the truck looks awesome.
