Running with only Parking lights during day?
pughde
SC
When lights are in auto mode they are now on during the day, like DRL. I made the Forscan changes above so not sure but I have DRL when in Auto mode during the day. I only wanted the parking lights to be on with the hood LEDs but I can always turn them off. I will check it out later, but apparently they are only on when in drive.
fidds22
Alberta
I tried with the Forscan also. I have it now in my cluster, but when i turn the DRL off, my truck has no lights on during the day in auto. That is not what i wanted. Someone will figure it out.
pughde
SC
I have not found a way to get parking lights on via switches. When this is found please post details.
R
Renomaan
I bought the factory shop manual for the wiring, once I get time, Ill post which connectors and pins run the Parking light setup your looking for for DRL only-then they can be jumped to the AUX which unpower when truck is off.
pughde
SC
Thanks I current have both low beam and parking lights on via Forscan using auto on lights switch. But would prefer the upfitter switch.
