Wow that’s so much easier. How did you remove the glovebox like that?
There are tabs on either side of the glovebox that allow it to swing down for access, the more time consuming part was gaining access to that grommet.
Thanks for the quick reply! Dropping the glovebox like that with the tabs allowed you to see that grommet?There are tabs on either side of the glovebox that allow it to swing down for access, the more time consuming part was gaining access to that grommet.
No, to do that I had to remove the inner wheel liner and the shielding (as indicated in the photo’s)Thanks for the quick reply! Dropping the glovebox like that with the tabs allowed you to see that grommet?
Inner wheel lining as in the black wheel guard in the wheel well?No, to do that I had to remove the inner wheel liner and the shielding (as indicated in the photo’s)
The outer fender flare (5 screws holding it on), then the inner plastic wheel linerInner wheel lining as in the black wheel guard in the wheel well?
