RPG Power Steering Reservoir overflow
  • Start date
Guest
Is it normal for quite a bit of overflow to happen when off-roading?
I was surprised how much came out the overflow tube. I need to get a longer hose if this will be a common occurrence.
Or could there be something wrong with the overflow value? Any way to test it?
Huck
Chicago Sw Burbs
I've yet to have any overflow with mine. Possibly you over filled it.
J DAMAGE
NJ
Huck is right, are you at or below the baffle in the res, I also ran a longer overflow line not to shit up under the hood.
Guest
Yes it is filled only to below the baffle. Actually I didn't fill it, installer did. I just refilled when I saw the fluid running down the suspension after a run.
The Macf
Vegas
In the video, they state that it's only supposed to be at the baffle when HOT.
Guest
Yeah, I refilled it after a run, so it was HOT.
Going to Raptoberfest. Will bring plenty of fluid. Will see how it goes again after a few laps. I was thinking that maybe I have a faulty overflow release value and didn't know if it was replaceable.
The Macf
Vegas
Never heard of that. Anything is possible. Most likely just overfilled.
tbone
the bay norcal
happens to mine too i just ran an overflow tube to a waterbottle usually after offroading i have some in there
Guest
That's an idea. Just a normal plastic water bottle? How did you attach it, black electrical tape?
tbone
the bay norcal
yup just hid it next to the airbox out of site so no one sees a random water bottle haha it was a quick fix i did on a run because i was tired of spewing powerstearing fluid all over but it works and ive been running it perminently.
---------- Post added at 01:47 AM ---------- Previous post was at 01:46 AM ----------
i got it from another guy that had the same issue on the run but he used the shampoo bottle you get from the hotel bathroom
