RPG Bolt on LT Kit
canamds450
What is the ride heigh on that set up? Do you need to use +3 leaf springs or you keep stock ride heigh with that kit?
paj1978
This is like how long is a piece of string...
I would say that doing this front and not changing the rear would lead to less optimal results...
RPG has a fantastic level5 for the back that nicely matches this front and it's what I run.
3.5 fox bypass through the bed in a bed cage, with +2" HD springs and new shackle.ImageUploadedByTapatalk1415800846.489316.jpg
RaptorSpartan
Austin, TX
But not for the same reason. With the dual 3.0 on the stock replacement lca the tite would rub on the bypass shock. With the longer lca the tire wont rub but a wider stance equals less turn radius
