Roush Supercharged Raptor Custom Tune by JDM Engineering
JimIII@JDM
New Jersey
Today we had our customer Jason Peaslee bring his 2014 Roush Raptor to our shop from West Virginia. Jason brought the truck 5 hours to New Jersey this morning and it was at our doorstep first thing this morning. We went right to work removing the factory installed spark plugs. A set of 16 NGK Iridium 6510 spark plugs replaced the factory Motorcraft plugs. The NGK plugs are a 7 heat range which is colder than stock and provide better spark and less chance of detonation. The plugs were gapped to .030" to allow for longer change intervals and to limit spark blow out from Boost. After the plugs were changed we strapped the truck down on the dyno and made a test pull with the Factory Roush tune. The motor had plenty of time to cool as the plugs took nearly 3 hours to swap. With the Factory Roush tune the truck made 439 RWHP on 93 octane. We loaded our JDM Custom tune in and made a pull no more than 15 minutes after our test hit. With the engine warm and the intake temps hovering around 20-30 degrees above ambient to start the run and the truck made 515 RWHP! We backed it right up with a 2nd pull and the engine full temp it made 500 RWHP on the button! Total power net gain of 76 RWHP !!! All this from a custom tune!
Now we are able to improve the performance this much only tuning the truck because Roush does have a very mild tune up in the truck. They run a very rich fuel mixture and limit throttle angles at both part and wide open throttle. As well Roush incorporates a 100 mph speed limiter which creeps up on a 650 HP very quickly. So we have raised that to 130 MPH, to go any further we highly recommend a Axle Exchange Aluminum driveshaft for better balancing and safety. On top of this our tune also provides better Shifting, Throttle Response, and all around Driveability. The customer stated he got 11 mpg average, now he should see about 14 mpg average on his way home going on what we've heard from other customers! All of this from simply installing our custom tune!!
Dyno Graphs to come...
After fighting with my scanner for the past couple hours :mad: I gave up and took a photo of the graph. I over laid the stock graph and the 2nd run of our custom tune, we started them at the same RPM and gear. The 515 HP run didn't look as nice over the stock run file. You get a better visual of what your gaining from our tune this way. As you can see from the hit of the throttle all the way to about 4,500 RPM we gain average 15-20 RWHP. As we climb higher in RPM the power gain increases. By 5,000 RPM (104.7 mph) where the Roush tune hits the speed limiter we are about 30 RWHP over the Roush tune. After the speed limiter is raised we can take the truck all the way to redline, 5500 RPM (113.5 mph) and peaks our total power output at 500 RWHP. A Total gain of 61 RWHP peak on a hot engine! What is also note-able the Torque gain also starts from the hit of the throttle and carries all the way to redline averaging about 30 lb/ft more than stock. A total of nearly 27 lb/ft of Torque peak gain!
*Stock ROUSH tune = Blue Line Run File_001
**JDM Custom tune = Red Line Run File_002
JimIII@JDM
Rodbender
Woodland, Ca
That is awesome Jim, I can't wait to get your tune on my Roush Raptor, my Livewire 5015 is still at SCT, they are trying to figure out why it wont load on my Raptor. I will run before and after dyno to see the increase in HP as soon as they get the tuner back to me.
Great write up
Rodbender aka Steve
cayenne
Windsor, CO
I can't wait for my warranty to expire so I can load this in my 2014 Roush... The factory tune is waaaay too conservative!
Blackhawk
looking forward to tune
Hi everyone,
Just got a new Roush 2014 screw with some easy mods made over this last weekend. I'm looking forward to installing the 65MM COBRA JET BILLET ALUMINUM THROTTLE BODY with the JDM custom tune. I'm not sure how involved the throttle body install is but I figured I'd give it a go.
Based on other recommendations I'd like to take my truck to a local shop in the cincinnati/dayton area for additional mods...any recommendations in cincy? columbus? I also have to have someone gap and install the iridium spark plugs.
Thanks for your help
ProjecT 9
Houston
What's the roush (tvs 2300) capable of power wise? If we can make 550rwhp with the whipple can't we do the same with the roush? Just curious
Blackhawk
The highest I've seen in 500-520 rwhp btu the guys at JDM with all the mods they do may know better. I know Kooks headers, tune, throttle body can get you closer to 550.
ProjecT 9
Houston
So what's the power curve look like between the two? Does one start earlier, carry longer? I'd think it's fair to assume the 2.9 whipple has more power potential with a built engine but for stock I'd imagine 10lbs of boost is 10 lbs of boost. Is the TVS not cable of being pullied down and spun that fast?
6.2Canadian
Vancouver
I pullied my Roush down for some extra boost,then put headers on and lost it again but gained power so that's good, and the difference between the 2 is so small that the only way you could tell the difference between the two is the whipple is louder.. But people will argue and I will tell them to argue with their trucks and they never do...
ProjecT 9
Houston
You have a graph? I'd like to see it.
JimIII@JDM
JimIII@JDM
New Jersey
Hi everyone,
Yes put a set of NGK 6510 spark plugs in and have them gapped to .030"
The throttle body is a 15 minute install, 4 bolts and two connectors. Direct swap for the stock unit and adds 15-20HP and more pedal response!
JimIII
---------- Post added at 12:16 PM ---------- Previous post was at 12:12 PM ----------
On a Raptor it is capable of the stated power above with minimal modifications. We've added headers and bigger throttle body and have made 520-530 RWHP. We try to keep our customers under 550 RWHP because of the stock engine internals and fuel pump. If we really got after it and added some more boost and aggressive tuning it could probably hit 600 RWHP!
The Whipple is a physcially larger supercharger 2.9L vs 2.3L. Remember we have TVS Superchargers same as the Roush R2300 making over 800 RWHP and running 8 sec 1/4 miles on our Mustangs and Cobra Jets!
Cool Video of one of our TVS Cobra Jets ;)
I say this to all of our customers, the Roush, Whipple, Procharger, or any kit when properly set up will make more power than your stock engine can handle.
JimIII
