Roush serpentine belt
MTF
Celebration, Florida
I have a question for you @Rapt Up,
I'm sure you are but just in case.
Are you using a 1/2 drive breaker bar in the 1/2 square on the belt tensioner and pushing it all the way down to loosen up the belt?
I cannot seem to find a serpentine diagram for the Roush, but I don't think the bottom half of the motor pulleys run different from the 6.2L stock or Whippled Raptor.
Whipple also added a adjusting idler pulley which makes using and changing different size belts.
I'll put up a pic of the Whipple diagram, If anybody has a pic of the Roush diagram please put it up
Rapt Up
Oldsmar Florida
MTF
That looks identical to my set up but its slightly different...(I could be wrong)....just cant put my finger on it...the Alt pulley is way bigger and the pulley to the right looks odd
I have the sticker under my hood...I can take a pic for you so you (and for others) so you can use it to compare
Matt
MTF
The top pulleys are different between Whipple and Roush, Whipple's gear box pulley is on the left of the alternator and the alternator is moved more to the center.
The Roush gear box is dead center and the alternator is not relocated.
If you are referring to the little idler pulley that is in between the belt by the power steering pump, it's not used.
Can't say why it shows a idler pulley there other than maybe the stock HD trucks and HD vans use that pulley location, they also run a 8 rib serpentine system.
HAP
NE NC
Are using a 1/2 drive breaker bar in the 1/2 square on the belt tensioner and pushing it all the way down to loosen up the belt?
If anyone still needs it, if you click on my user name I have the Roush belt diagram as my profile pic.
R,
HAP
Canuck714
San Antonio TX
Just to chime in, Ive had the GATES on now for 5000 miles no issues. I had Roush send the FEAD shield but have not needed it since the belt change.
Ive been offroad with heavy on/off throttle and zero issues.
Shorter belt seems to work
imnewhere
VA
I just broke my Roush belt while on vacation. Belt had right around 50k miles on it and I replaced it with the Gates one. No issues yet other and it being an absolute pain to get it installed. If you have a ratcheting 1/2" drive I'm sure it would make it a lot better, the angles for setting the non ratcheting version weren't good for me.
MTF
Yeah having a buddy reach in from the driver's front wheel well and holding the tensioner down for you makes life much easier.
Reddog2
Michigan
Just an update to this, my belt broke so I ordered one from Roush on Friday afternoon, got an E-mail on Monday that states Dayco belts discontinued that belt for Roush, they're working on getting another suppler....but nothing yet. So I ended up getting one from Napa which is a green back HD one.... part#061251HD. Think I seen on here somewhere that it should fit with some TLC.
MTF
Gates rebrands for Napa
The last four numbers are the belt lengths.
The Gates K061247 (124.76 in.) or the K061251 (125.09 in.)
These are the two sizes the Whipple uses and will work on a Roush depending on what pulley size you're using.
You can replace one or two of the idle pulleys to a smaller diameter to accommodate both lengths.
Gates now makes a racing line for the Micro-V belts, K061251RPM
Specifically designed for high-output and forced induction engines.
But expensive!!!
125.1 in.
124.7
Fleet Runner Green Back HD
