Roush s/c low power on dyno
JimIII@JDM
New Jersey
The Dyno in use we are not familiar with for power numbers. Most of our vehicles from overseas we also leave with a more mild timing curve due to difference in fuel quality. This it to keep your motor safe. I don't know how much power the truck would make on a Dyno jet like we use here but a rough estimate would be about 450 RWHP. 500 RWHP is on our 93 octane tune up. I don't think you received that being over seas. With a tune like your's you would have 2-3 degrees less timing resulting in less power. If you have confirmation of good fuel quality then we can adjust the tune for more power.
Was the Air fuel ratio measured on the dyno? Log timing and see what your hitting at WOT.
---------- Post added at 11:13 AM ---------- Previous post was at 11:07 AM ----------
Just read your tune sheet you filled out and saw your note "Looking for a safe tune that wont ping in hot weather (Australian climate)"
So I'm sure you have a very mild timing curve. Not 370 RWHP worth though, that's due to the dyno being used. Your probably around 450 RWHP like I expected.
HAP
NE NC
They didn't do a base run before mods?
Boost can vary by 1 to 2 lbs. depending on exhaust and SC pulley size.
But 8 is the baseline.
To me, it seems they did not setup the parameters correctly.
Most dyno shops always display HP & Torque with a boost graph on the bottom for superchargers.
You may want to invest in a OBD11 adapter and a phone app.
Our PCM is capable of displaying HP & Torque at the flywheel or rear wheels and Boost plus a lot more.
Most importantly the fuel trims!!! Short & Long
This way you'll know if its installed correctly.
MTF, any recommendations on the adaptor and app for the performance info?
Thanks,
HAP
HAP
NE NC
Thanks MTF!
Just ordered the WiFi dongle for iPhone.
I really appreciate your time and recommendations.
R,
HAP
RubyRedRaptor
RubyRedRaptor
Sydney Australia
Well I dug deep into the nether regions behind the supercharger where no mans hand is meant to go.
I found the bypass line felt like it was pinched behind another hose and firewall
I freed it up, so hopefully that's was the cause. It would limit the vacuum being able to close the bypass fully.
It feels snappier now with boost coming on at a smaller touch of throttle.
I'm not sure if this will give me the figures on the top end I'm looking for but at least I found something wrong
