Rogue Racing stage 4
Jag
Cypress, TX
It may have been mentioned and I just can't seem to find it. With this setup does it change what can be towed or how much can be carried in the bed? If so, what are the new limits?
Rogue Racing
Yes, it will be a softer rear over stock leafs. We custom order the Deaver Leafs depending on how much weight the customer permanently Carries in the bed. The towing tongue weight is adjusted by a set of simple airbags that bolt in place where the bump cans are. This will be available in about a month. I will do a write up and have pictures.
Thanks Ryan
Jag
Cypress, TX
Thanks Ryan
Will this be a completely new 'bump' setup, or will it work in conjunction with the current.
I need to get bumps before TRR, at a minimum, but would like to do so with my long-term choice in mind. I still need to use my truck as a normal truck, not just as my OR toy. I do plan to add a removable bed rack for adventures, but have occasional tow/haul needs, and while I can probably handle losing a bit on the max load, a big sacrifice might point me in another direction for suspension.
Rogue Racing
Will this be a completely new 'bump' setup, or will it work in conjunction with the current. I need to get bumps before TRR, at a minimum, but would like to do so with my long-term choice in mind. I still need to use my truck as a normal truck, not just as my OR toy. I do plan to add a removable bed rack for adventures, but have occasional tow/haul needs, and while I can probably handle losing a bit on the max load, a big sacrifice might point me in another direction for suspension.
Our bump stop system works with the cantilever system or by itself. We designed our components to be built upon starting from Stage 1 through Stage 4, there are only few exceptions like our upper arms.. you have to start with heimed uppers rather than bushings to work with Stage 2+. We realize that going full Stage 4 up front is not the most affordable option, so we wanted to make a more versatile suspension people can build upon over the years.
Sent from my iPhone using Forum Runner
Hole Shot
Raeford, Nc.
@Rogue Racing have you guys ever installed or made a rear off road sway bar system for a raptor. I'm having some issues pushing in corners with no front sway bar and I'm not willing to start over with my front end?
Rogue Racing
@Rogue Racing have you guys ever installed or made a rear off road sway bar system for a raptor. I'm having some issues pushing in corners with no front sway bar and I'm not willing to start over with my front end? Sent from my iPhone using Tapatalk
Not yet we are working on one though and I will post it here as soon as I'm done testing. It uses a Pac Swaybar. Probably will release by Mid April
Thanks
Ryan
