Rogue Racing Spare Tire Carrier and Bed Support
t_j
Chicago, IL
So here are my post install notes:
- Required people 2
- Install complexity 3-4 beers post completion plus a 6 pack for your helper
- Check your bed bolts before installation time so you don't end up wasting time welding a socket to a stripped bolt (luckily I have a few spare bolts hanging around)
Some thoughts:
- There was some heat warpage of the drivers side frame that made it very difficult to get everything into place without the help of some additional clamps.
- The disk on the tie down handle is to small for a method wheel it slips through the center allowing the handle to mar the inside lip of the wheel
- Although stated otherwise it will not fully work with a roll-x cover, the rails for the cover touch the side of the tire and could cause wear to the sidewall if there was any movement
Overall I am VERY pleased with the product and will be working out a solution to the center hole problem.
Daweism
Austin, TX
Hmm, any future options of maybe bed support setup on both sides but with for a single-spare tire mounted laying flat in the center-rear of the bed? Or a custom order perhaps?
Jimbo
Jimbo
Mad Frog Mattis
IL
I'm sure we could, but then you're really limiting the other bed space, but it's up to you!
CoronaRaptor
CANADA
Is there a plate in behind the inner box side where it's bolted on where the wheel would sit?
Never mind, I just seen it in one of the pictures ;)
Daweism
Austin, TX
Good point, or perhaps just one spare that can be mounted flat on the passenger side, I'd go for something like that.
