Rogue Racing Front Suspension Stages and Pricing
ntm
Alberta, Canada
The prices are very reasonable when you take the fabricated spindle/knuckle into account.
The stage 4 and under is designed for stock and the usual 3.0 coilovers.
canamds450
Front suspension travel?
Stock lenght or +2" per side at stage five?
Rogue Racing
Rogue Racing
It is +2 per side.... Travel is Strapped at 17.8"....
---------- Post added at 07:54 AM ---------- Previous post was at 07:48 AM ----------
Stage 1, 2, and 3 have Horizontal upper arms. Stage 4 and 5 say Vertical. Can you explain what a Vertical UCA is?
-Rob
We are referring to how the UCA Mounts to the Spindle... Here is a picture of our Horizontal mount:
Here is a picture of our Vertical Mount UCA:
---------- Post added at 07:56 AM ---------- Previous post was at 07:54 AM ----------
What are the travel #'s of your front King Shocks compared to the other options available? Your rears are substantially more.
Which Stage Kit of ours are you referring to? We use a few different shocks so I want to make sure and get you the exact numbers...
RangerRob
Ramona, CA
Thanks for clearing that up. With the stage 5 kit, will the lower arm have a uni-ball on the end mounted horizontally or will the uni-ball be welded to the spindle vertically? Hope that makes sense!
Rogue Racing
Rogue Racing
Without trying to confuse everyone... The Lower Control Arm uses a Uniball that mounts like the factory Uniball Mounts... It is however much bigger...
