- Joined
- Jan 19, 2015
- Posts
- 304
- Reaction score
- 417
How many hours did it take them to fit those up?
. What are you doing for a rear bumper?
Robby Builds the BEST CF out their for the Gen2 bar none! They fit like OEM!
The front fender R&R takes about .75hr per side longer than OEM because you need to drill out the mounting holes as you fit them. But you will need to fab / mod the inner wheel wells as the stock ones will not work.
The rear sides R&R in about the same amount of time as OEM. But you will need to fab inner wheel wells and support bars as the stock ones will not work
I was wanting to do the honeybadger rear, but with the way the rear fenders go straight down I don't think it will fit. I was going to see if I could cut it down where the ends tuck under the regular bedsides, but I'm not sure the lines will look right. Do you have pics of the bumpers on it now that the fenders are on? I was thinking of doing the Stealth Fighter front. It should look ok, and not be too short on the ends I hope.The rear is a ADD PRO that I just put spacers on for now an it is a little to short.
The Front is a ADD PRO an is a little short and the angle need to be changed.
So I need to decide if it's better to mod them or just have Robby build custom one's when he is installing the LT front.
Edit: I looked through your build thread and found the pics with the bumpers, so no need to repost those unless you just want to. Thanks.
Are you sticking with 37" tires after you get your LT kit installed? Ideally I'd like to go with just the RPG BOLT set up and be able to run 40" Toyo MT. I know they will fit with the Deberti fenders, but not sure if Robbie's go out and up as much as the Deberti. I'm also not sold on going with carbon fiber since I would likely paint them to color match, which would cover up all that pretty carbon anyway. I'd do carbon if there was some other good reason though (strength, fit, etc.).
