Rigid SS Fogs, XL Hyperspots snd Ignite
Uncas
Uncas
Heading to Colorado
Very nice
Could you post a link to the back lights ?
I’d like to do that
Was it a plug and play kit with the wire harness to go to the uplifer switch ?
I didn’t get the harness, instead I ran thru the frame back to Upditter 4. I plan on using them more for trailer hook up and area lighting. But if i need them for backing up, I’ll just flip the switch.
https://www.rigidindustries.com/ignite-backup-kit-bu-ignite.html
I ran the left light wire in 3/8 flex thru the hitch and spliced with the right. It took a little work with a fish tape to pull the flex thru the frame but it’s a clean look. Just need 25 feet of 3/8 flex and 16/18 gauge red and black wire.
gto19
Very nice work
That’s exactly how I would do it .so it looks like the light mounts up using the hole right next to the tow hook . So no drilling it looks like . Correct ?
I will also go to uplifter 4 since 1,2,3 are.
Being used up front with the fog lights
Again thanks!
Uncas
Uncas
Heading to Colorado
Very nice work
Again thanks!
Yes I used the existing holes in the bumper. I had to make one hole in the wheelwell liner for a ziptie. No new holes for the front lights. So far my 18 has only factory holes in the aluminum and no cut wires. Think I might have to drill some in the bed for my recovery box though.
Nick@Apollo-Optics
That's a great setup and I'm happy to see that the Dually XL can be squeezed in there with the D-SS lights.
If anyone would like to go with a similar setup, please reach out and we can help get you setup!
ewm98
Arizona
Did you buy the mount for the SR-Ms or did you fabricate it yourself? I’m having a hard time finding a way to mount mine correctly.
Uncas
Uncas
Heading to Colorado
I used the Diode Dynamics bracket and bought a longer stainless carriage bolt. I put two washers and a nut before the fog light bracket to adjust the height.
ewm98
Arizona
Maybe I’m missing something here but how did that get the Rigid logo on the SR-ms to be facing the correct way. On mine they are upside down. I sincerely apologize if I’m missing something obvious here.
Here’s a picture of what I’m talking about.
Uncas
Uncas
Heading to Colorado
Ok, I got it now, I switched the cover 180 degrees even though Rigid said not too. Two Allen screws in the back allow for removal of the lens. Rotate and reinstall.
