Rigid Radiance Scene Rear Lights Installed
Gatica
Southern New Jersey
you have the Diamondback cover any chance I can see the full picture. Im debating on purchasing it. I like the fact that you can load on top of it.
RotorOver
RotorOver
Greater Atlanta
Here you go! Love the cover! I went with the smooth SE and have been running it slick, just cause I like the look and haven’t needed to use/install the cleats. I highly recommend the Crossbin as well. It really proves out the reasons for having a front opening cover especially combined with an AMP Research Bedstep or two for side access.
Gregger
Denver, CO
I went with the S2's and just installed them today. Similar ground point. Wish the up fitter wiring was a bit longer. I had to pull the battery to find them and to add quick connects to them for when my 3 pairs of fogs come in.
RaptorMan703
VA
Looks great man! I have some leftover Scenes from my Gen2.
Is there a way to have the white light activate when in reverse and via upfitter switch but not have the red backlight your picture shows?
I seem to remember a spare wire just for backlight, would I just leave that disconnected?
RotorOver
RotorOver
Greater Atlanta
Thanks! Yeah, you don't have to power the backlights if you don't want. You are exactly correct. You've got a few options with @Specialtyperformanceparts harnesses.
