Rigid fogs
bled656
phoenix Arizona
Hello everyone, pretty new to this forum, just got my new 22 raptor 35, the inner fogs don’t come on, i tried aux switch 1 and all of them and they won’t turn on, any other thing i can try? Thanks in advance!
HighwaySentinel
︻デ┳═ー - - - - - - -
California
One set is controlled by the Aux 1. The other set is controlled by pressing the center of the headlight selector dial...with low beams on
HighwaySentinel
︻デ┳═ー - - - - - - -
California
Something must disconnected or something it’s not working woth the aux1
Lots of problems people have had with fuses that are not properly seated. Check all those. After that, may have to take a trip to your friendly Ford service dept.Fuse.jpg
Antho
Refreshed my memory. Check this wiring diagram.
Check fuse 62 in the fuse box under the hood.
B
bled656
phoenix Arizona
You have the fogs turned on? You see the fog light emblem on the dash? I cant remember which set is on the Upfitter and which is on the factory fog switch.
The
The outter fogs turn on and the fog light on
fuses are good, so in my bronco when i push the switch on they turn orange is that supposed to be the same on the raptor? I turn them on and blue light goes off, also switches 3, 4 and 5 don’t stay on, is that normal?
Antho
@bled656
Yea, the upfitter switch light turns orange. When you say the other don’t stay on, what do you mean?
