Rigid Dually back up lights installed
GTS RAPTOR
Aux back up lights or aux rear lighting lights installed, they work great!
Hooked them up to my last available upfitter switch, switch #1, so I could have independent control of them, rather then wiring them into the reverse lights wiring.
I refused to a 20 amp fuse in the fuse block and then ran an inline water proof
fuse holder and installed a 5 amp fuse in it.
Java
MI
If you don't want to go with the leaf spring mount you can use the 2 inside bolts on the bottom of the bumper. That will get the light out up a little higher than the lower mount can do. I didn't need quite that much light and went with a single light next to the hitch. It provides enough light for my needs. If I was going to use two lights I would put them on the bumper. When you are installing, you can see that it doesn't impact the departure angle with either application.
97,000
60,935
Skoobz
