Rigid Dually back up lights installed
IRONMAN
Well-Known Member
MICHIGAN
Nice mod!:waytogo:
Could you snap a close up pic showing how the dually light brackets are mounted to the rear spring hangers and post it up please?
Now I know what to use my last upfitter switch for.:)
How about some big pics of your baby there GTS. That looks like a nice set up.
pirate air
pirate air
will plunder your booty
do you have a backup camera on your raptor?
Yes I do.
No, he just likes to **** off tailgaters :naughty:
They work well for that too.
Nice mod!:waytogo:
I will get some pics after work tonight for ya.
And since I know you will read this, not that kind of pics BIRD!!!
pirate air
pirate air
Side
Bottom
Back
I used different bolts to mount the bracket to the spring hanger then the ones supplied by Rigid. Their bolts broke when I tried to tighten them to keep the lights from moving.
GTS RAPTOR
I forgot to ask you about the wire harness.
When I got the 2 pair of amber duallys for the front bumper of the raptor, the wire harness was raptor specific, made to fit with the correct length of wires and connection plugs.
Did the pair of duallys you got for the back up lights come with a wire harness that connected the two lights together?
Then you had you add wires to make the run to the front of the truck?
pirate air
pirate air
Thats pretty much what I did, but I'm trying to remember what exactly the dually kit came with wiring wise. It's not Raptor specific, so I ran my own fused power wire to the back from my up fitter #4 switch. For the ground I tapped my trailer 7 way pin ground wire, since it was close. The kit came with a harness that had a switch and an in line fuse that I cut off. The main harness has a connector for one light, they give you a second harness for the other light, and scotch locks to connect the harnesses together. Its something you wont need more than basic automotive electrical stuff to do. Wire, butt connectors
(or solder an heat shrink), spare scotch locks, electrical tape, and zip ties and you should be set.
