** RETROFIT HEADLIGHTS **-Custom built HID Retrofit pics and pricing
R
RSiWORKS
S.C.S. Michigan
Oh BOY!
Dual projectors anyone??? lol
In the testing phase right now. Main projector is the EVOX-R 3" and the Off-Road projector is 2.5" Xenon projector Hi only not Bi-Xenon with a shroud that will be painted to match.
Don't mind the light itself, it's a test light that's been through hell and back and scratched to shit.
IRONMAN
Well-Known Member
MICHIGAN
Oh you will get very excited once I build mine next week. Had to go back to the Laser cutting co. to tweak the mounting brackets but these things should be "AMAZING" I kid you not.
They will have a RIDICULOUS amount of light output for headlights.
Where else can you get Custom built headlights with OFF-ROAD lights built in.
No where!. :signs6:
Wilson
South Dakota
a projector without the shroud shutting down light is going to be a lot brighter than any rigid wouldn't it?
IRONMAN
Well-Known Member
MICHIGAN
What are you gonna ask for that setup Rog?
Sorry, missed your post. Not quite sure yet but it is gonna be quite a bit more because now we have "4" projectors with "4" specialty brackets custom built, the main projector is upgraded now from the mini H1 to the EVOX-R which is a more expensive projector.
My goal will be to keep it close to the 2K mark and not go over too much.
These lights have 4 projectors, 4 halo rings, 4 ballasts, 4 HID bulbs and Hi powered LED lights for marker/ DRL/ sequential turns and also now 2 shrouds custom fitted.
All in all this light is PACKED with all sorts of goodness. lol
I pulled off my lights to use for test dummies and had to put on my stock ones, WOW they were terrible. I missed my lights so much driving through the country just couldn't see shit.
The plan is to fully convert the front signal and marker lights to all LEDs with the stock bulb hidden to control hyper flash.
Should look pretty killer.
These head lights with the built in Off Road lights would blow away any Rigids mounted in the headlight housing.
You wouldn't even know they were there.
I have some small cube KC lights and with all my headlights on you can't tell they come on.
Now a bigger light bar would make a difference.
