Wilson
Make sure your line is not kinked or plugged yep that's all I got
no...runs off pcm
Really dumb question, how old is the gas? I'm assuming it's a fresh tank? How about the oxygen sensor?
By the way you truly amaze me. I could never do this.
Sent from my Nexus 6P using Tapatalk
OK... no vacuum leaks.
Three different techs from three different Ford stores all said "BAD THROTTLE BODY" ... so I ordered one today...be here on Wendesday...keep ya posted...
so, the throttle body did not fix the issue...tech at ford that was with me said change the RCM (restraint control module), the truck may think it is still in the accident and shutting off the fuel pump...maybe...
check fuse #27 under the hood see if it's getting melted. That is the for the fuel pump.
