Remove front seat
Madcowranch
Genetically Modified
OK
Any tips on removing front seats?
Airbags aren't going to blow up or anything right?
Baddkarmaracing
slide them back all the way and unbolt the front bolts, slide forward all the way and pull the back bolts out. unplug the connectors ( 2 I think) and pull the seat out of the truck. airbags will not go off just make sure you leave the key in the off position when unplugging the connectors
MTUH3
Plymouth, MI
Just be aware of the connector. 9v across the connector will set the airbag off. You may already know, but anything yellow, connector or wire, is related to the airbag
Rookie
Fort Wayne, IN
^ what they said. Not sure if what you're trying to do but I left the seat belts attached cuz they were going back in shortly. I believe the drivers side has two plugs but the passenger side only has one.
no problems heifer. just do as mentioned already and you will be fine. the good thing about fords is that if you have to, you can turn the key with the seats out. but once you plug the seats back in, the airbag light will turn off. i had to move my truck several times with the seats out and didnt have an issue with the light. not recommended, but if need be, it can be done.
Madcowranch
Madcowranch
OK
Awesome. Thanks guys. I had no problems and already have it back together. My tilt mechanism under the passenger seat had rattled loose at TRR so no biggie.
Flying_Raptor
Dallas, TX
my passenger seat is stuck in its current position. it will slide forwards and backwards but no luck going up or down.......
Madcowranch
Madcowranch
OK
Look underneath and see if the bolt between the tilt shaft and the rail came off.
i just realized i only have 2 bolts holding my drivers seat in place. i only put 2 in to move my truck a couple weeks ago and never put the other two in...... oops
