Red Tow Hook
danbjeff
Looks really good. Did you remove the front skid plate or just pull out the hooks from the front. I watched a video of a guy leaving skid plate on and pulling out some gaskets around the front hook before unbolting.
Finally got them put on. Yes, I removed the skid plate. Just makes it a lot easier.
Matches the orange in the hood decal perfectly.
Gen3Rappy
Orlando, FL
Love the red tow hooks, had them on my 22’ Code Orange and looked good as well. I always pull them right out the front. Pull the rubber gasket out and loosen back bolt and fully remove front. Takes about 10 minutes total.
alockbox
US
Any chance you could walk through a little more details? Getting ready to do the 2024. Also love your lower grille insert. I'd be looking to do that as well once a matching 24 is out. Care to share where you got it? Thanks!
alockbox
US
I figured this out on my own it was pretty easy. Remove the skid plate, look towards the back of the hooks for two bolts. Remove the one that is straight through, loosen the one that is a keyslot, slide them out. Paint and clear coat and put back. The plastic trim around the hook concerned me since it looked like they needed to go on with the hooks, but was very simple to get back in place after the hooks. Pretty flexible.
I used Kustom Canz paint code CN for code orange and couldn’t be happier. Went with the spray setup with 2k clear coat. The clear coat is phenomenal stuff but be warned it needs to be used in 24 hours since it’s a 2 part mix-in-can. Get everything ready to want to paint and do it all at once.
