GEN 2 Rear seats heater not working
Szabo Mihaly
Romania
My Raptor rear seat heater is not working and never worked. The switch is there but the small LED is not coming on when i try to switch. I checked the fuse (no 94) and is ok. Both seats of second row the same issue.
The front ones has no problem.
Any idea? Can be Forscan?
Sent from my SM-N975F using Tapatalk
Terry
Springfield, OH
If it's still under warranty, I'd take it in to be fixed. Otherwise, I'd start by checking fuses and testing the switch to see if it's working.
S
Szabo Mihaly
Romania
I have no warranty. I am in europe and the raptor is brand new.
Try to pull any diagnostic trouble codes or DTC. A simple clearing of any codes that are related may fix it. You may use Forscan to clear codes.
S
Szabo Mihaly
Romania
Finally i got an adapter for forscan. There are no any trouble code after 12.000 km. I was really surprised.
But my rear seats are not heating. I suspect that maybe i need to change something in with forscan.
Maybe some of you can help me with the correct codes for heated rear seats?
