Jhollowell
I've been having an interment issue with my passenger side rear door lock sticking. Every once and a while only that door won't unlock using the power buttons but if i pull on it, it'll unlock and then work smoothly. It takes quite a bit of force to unlock it, but once its unlocked it cycles with no issues. It seems to be random when it decides to stick and I can't inspect the mechanism when it does stick because the door is closed and the panel is on. if i unlock it by hand and pull the panel, everything is working as it should so i can't see whats causing it to stick. I guess i could just pull the door panel off or a few days and wait for it to stick and see if i can see what the issue is, but i think it'll still be tough to examine the mechanism with the door closed. Anyone have this issue and find what was causing it?
