Rear Camera Intermittently Not Working
GWBush
Houston, Texas
Mine shot craps last year, 2010 and 155K miles. Replaced with Amazon compatible camera, works like a charm. No issues.
cjgambill
Idaho Falls ID
Hey Guys, replaced my rear camera, the wire connector, the housing, and emblem last night in my 2012 SCREW and didn't need to access forscan to reset. Worked perfectly. Here is the parts list that I used. The main thing is to make sure you use the old cable to pull a string through; cut the connector off and tie string on then pull the new one through with pull string which will make it easier than trying to fish it through there.
American Trucks: https://www.americantrucks.com/f150-rear-park-assist-camera-592-079.html
Rear Park Assist Camera (12-14 F-150)
Item T565867
Amazon: https://www.amazon.com/dp/B00X6RZ5H2/?tag=fordraptorforum-20
2009-2014 Ford F-150 Tailgate Back Up Camera Housing Bezel & Emblem UPDATED OEM
Amazon: https://www.amazon.com/dp/B00TNEPHCK/?tag=fordraptorforum-20
Ford 2011-2014 F-150 Rear View Back up Camera Wire Harness OEM BL3Z-14A411-A, Regular
Youtube Video: 2011 Ford F-150 Rear View Camera Replacement: OEM parts and Calibrate it yourself.
Gary E
Gary E
Medford, Oregon
Item T565867
Good info. What was your decision process on getting that particular camera?
