GEN 1 Real Carbon Fiber Climate Control Trim
BoostinChick
West Chester, PA
Was not a huge fan of the Di-Noc (vinyl) and hydrodipping was expensive and I did not like any of the patterns I saw at various shops - it looked too fake to me. I looked into carbon fiber skinning and materials were actually cheap! The drawback is that it is time-consuming. I started with the climate control panel and the piece directly underneath that has the Microsoft SYNC badge. Don't worry! This trim piece had deep scratches along the top and some minor damage. It was a good sacrificial piece. I had to fill it in and sand smooth...
I chose a honeycomb pattern to be different. Everyone has or does the 2x2 twill.
This was after the first resin coat dried and I was able to trim any excess and cut out the sections I needed to.
3rd coat that's drying now. Tried to show the 3D effect this has which is pretty cool. For my first project and working with real carbon fiber, it turned out OK. I still need to wet sand and polish to get things even.
Booth9999
Idyllwild
Nice! I like the pattern. I’ve always wanted to try this, how difficult was it to work with.
B
BoostinChick
West Chester, PA
Wasn't too difficult just had to think differently (if that makes sense). Meaning, it's not like vinyl or super stretchy. When you lay down the carbon fiber material you have to try and not stretch it so getting around corners or complicated contours can be tedious. To get any sort of sharp edge I had to fold it over and tape it down. Makes sense why people invest in vacuum bag type set ups if they do this often.
MasterKeebs
Denver, CO
Curious to find out where you ordered your material from?
Xtinct
Nebraska
Be sure to spray it with a urethane clear coat so the UV protectant will keep the epoxy from yellowing.
