Raptor R button
gto19
Hey guys
How do you get your settings to save . I can’t get them to save for some reason
TX-RAP70R
TX
you got to hold down the R button and will prompt you if it has been saved.
gto19
gto19
I have tried that and nothing ever saves . I will try again
Thanks
ams mike
Orange County, CA
Try this....
Choose your settings first. exhaust, suspension, steering.
Then press the R button once to bring up the screen. Then hold the R button until it saves the settings.
Once saved, you press the R button to bring up all your preset settings. Must press after you start the truck each time. Does not turn on when truck starts unfortunately....maybe a forscan code can fix, not sure!
New recaros
Colorado
Try this....
Well that’s almost a waste if you have to push a button each ignition cycle
GCATX
King Dingaling
Central Texas
Naw, it's a good thing. 2 quick taps of the button and i am sport mode and baja exhaust. Otherwise you would have to look at the screen and toggle up and down for each setting. I don't use it but about once a week, it's perfect. I sure don't want it starting in baja exhaust in the mornings.
ams mike
Orange County, CA
there is a setting for startup in quiet mode. I think there should also be a toggle in the same section for startup in R mode if one chooses.
NickyF25
PA
That is how I have mine setup too and agree is nice. Also have quiet mode remote startup set from 9pm to 9am.
