Raptor Lean
The Macf
Vegas
and few pounds for driver ;) Had to go look and it looks that truck is tilting DS but bed looks pretty straight. So if i get truck straighten, bed looks weird. So then i need solution for that :)
Jump it a few more times, everything will either even out or be even more crooked. Either way at least you got air.
MTF
Celebration, Florida
Bed should be in line with the cab!!!
The front and back driver's side should be 1/4"+ lower then the passenger side.
This is measuring the bottom of the fender wells to the ground on very level surface.
Deleted member 12951
Guest
Do I care?
The Macf
Vegas
First time I saw it I thought they were power braking it.
******* tacos. My X-Runner was lowered 2" and still had a 1.5-2" lean on the drivers side. Raptor, I can barely tell and I'm still on stock perch.
MTF
Do I care?
Holy Crap, that's a lean and the cab is not straight with the bed.
I wonder what's up with that.
Lost the Nitrogen in the driver's rear shock maybe??? It's only 15 psi. with stock shocks but that could make the difference.
Leaf spring failure maybe?
That would drive me nuts!!!!!!
First week of ownership 11/30/2010
I'll take a new one and post later.
Guest
Do I care? NO
Its the raptor lean. The bed is full and full tank.
