Raptor Fit in 6'7 Parking Structure?
BajaFred
Lots of garages have conduits, boxes, gear that hang down from the ceiling well into the "clear" space so watch out for that as well
Sitdown
Suburbia, IL
Does anyone know if the Gen2 Raptor will fit in a 6'7 max height parking structure?
Looks like the truck is between 75.5~77.3" in height.
My existing truck says 75~76.7 for height and it fits fine. So less than an inch taller at max I'm thinking I'll be ok?
I'm in and out of many office parking garages, most 6'6"-7'2". Not all same height garages are created equal lol A 6'8" stated height is usually the minimum ill enter into, and then crawl through looking out sunroof first time through. Lots of variances at certain points. I avoid certain areas of our 7' stated garage, but most places there's way more room than you think. The factory antenna is several inches higher than cab, so as long as that's is clearing you are typically good, id occasionally rub mine slightly with midperch+ in certain areas of the 7' garage.
Another member had the great idea to cut his factory antenna down to ~2" or so above the roofline. Better idea to warn you if using 6'6-6'8 garages, but not annoy you daily.
B
baja714
yeah as long as the antenna is confirmed taller than the truck thats good to go off that way if i see the antenna touching im backing up for sure. i took the work van into a structure once cuz there was absolutely no parking a anywhere. antenna started touching so I started creeepin through and all a sudden SCRAPE. lol scratched that ****** up good, good thing they never checked the roof [emoji23]
