Raptor Air Oil Catch Can
wiz1500
I am also very interested in a high quality can... Sourced specifically for the 6.2 .
One thing to bare in mind also guy's about return draining is you can actually create problems with vacum if this is not done correctly..It's NOT just a matter of connecting the drain valve (if there is one) to the dip stick or valve cover.. You could render the PCV useless and put to much vacum in the crankcase.. As any high end engine builder will tell you a negative crank case is a very desirable thing.. But using un-metered engine vacuum is a very bad way of doing it..
Just some thoughts before (I-we) try to get to creative..lol
Reptar
Jersey
Did anybody contact JLT about bringing their truck there for getting them to build us a kit? One guy posted he could take his there but never heard back if he did or not.
Scott13
Goodyear, AZ
I have been an avid user of catch cans on my N/A engines for a long time.. well worth the small investment. I have not had a chance to get one for my Raptor yet but it will be one of the first things she gets added to her.
Gunner75
SW KS
My throttle bodies like it a little dirty. I am not knocking any product, what you do on your vehicle, etc, etc, but seriously?
What do these kits run?
wiz1500
The man benefit is to keep the oil out of the intake..
This is more of a "over time" power sustainer then a power adder..
Not only will the oil start to coke up on the T.B. but also on your injector tips..This is the main reason for a dirty injector. Also the coking will start to disturb air flow threw out the entire manifold..
Also there is a number that can be found mathematical in the BTU number stating that the oil contaminated air is negatively effecting the thermal output of combustion. You will never see this on a dyno but it does exist at some level.
So this is more of a "sleep good at night" kinda product..
Todd Turbo S
Nor Cal
For under $200 it's cheap insurance...and it looks cool too
The main reason I bought one, is, I'm purchasing a Roush Super Charge kit after I get at least 1,500 miles on the engine and its my understanding there is even more of a need and benefit when a supercharger is involved. As long as it can't cause any negative effects, IMO it's worth the money. Todd
ray101381
Alexandria, VA.
just got my moroso kit installed, very easy install fit is great, i painted the mount black as stock it is plain sheet metal and stands out in the engine bay
