raptor 37 wheel specs
robopop
San Francisco
curious if someone has the exact specs of the raptor 37 headlock wheels.
I've found a post that references a 1.2" positive offset, which I'm trying to convert to backspacing.
Assuming an 8.5" wheel, is it correct that a positive 1.2" offset would equal a 5.45" backspacing?
((8.5 / 2) + 1.2) = 5.45
Thanks!
I'm going to measure the spare, but getting a precise spec would be nice since I don't want to remove the tire to measure the precise backspace.
R
robopop
San Francisco
what I found online suggests you need to add 1" to the width, which would produce a backspacing of 5.95
Can someone tell me if I'm doing this right? Thanks in advance!
Kojack19
CT
126381B9-E457-4B89-9330-88A4EEA5166F.jpeg9BCC38E0-1C9F-483E-908B-013783BE9D75.jpeg0E197B02-DC6D-44E6-9122-13C39822B37E.jpegDC6F2776-C9F4-4585-A10F-C675354BDF80.jpeg
Will try and get some better shots tomorrow-weather ain’t great today. BFG 37x12.50s on Method NV now called 305s with zero offset. RPG 1 1/2inch collars-no rubbing, no cutting, no hamering at all. Plenty of clearance and a full size zero offset spare underneath with zero issues. Couldn’t be happier. More to come after a proper drive.
996GT3
Oregon
Will the 37 wheels fit on the stock 35 tires? Like the 37 wheel but don't need the 37's for daily use.
