Raptor 2010 transmission problems
stephan1075
germany
Hi. I habe a Raptor 2010. it only works in gear 1 to 3. shifting to 4 happens but then no forward power anymore. the gearbox works from 1 to 3 quite harsh. solenoids, clutches, entrance shaft, leadframe and hydraulic block all replaced by new parts and PCM was programmed successfull. still only gear 1 to 3 works. any idea?
MTF
Celebration, Florida
@stephan1075
What size engine? 5.4L (early 2010) or 6.2L (later 2010 1/2)
First, can you tell us what error codes are showing up with a OBDII scanner.
Have you checked speed sensors at the wheels?
There is an input and output speed sensor for the transmission.
Check the wires from the PCM to the Transmission,
that wire harness does come loose with age and gets melted by the exhaust manifold.
mprice1234
SVT Gen 1 Rules
Colorado Springs, CO
Did anyone actually trouble shoot this issue or just started throwing parts at it?
ograptor
Masshole
When I had my issue recently, I had changed the separator plate in the valve body, replaced a shift solenoid , and a square seal between the case and valve body. I also put in a cooler bypass and shift improvement kit from Trans go I believe
MurderedOutSVT
Brodozin
The ATL
What was yours doing
