Raptor 17" brake kit
Warren-RB
SoCal
W
Warren-RB
SoCal
How our brake design compared to OE and others in brake bias:
W
Warren-RB
SoCal
Front 4 pot caliper stock size (350mm) kit.
Brake pads are the same as Dodge Challenger/Charger; Jeep WK1 SRT8 front.
Rear 2 pot caliper stock size (348mm) kit - For those with rear drum brakes only.
Brake pads are the same as Mitsubishi EVO 10 rear.
W
Warren-RB
SoCal
Do you know you can purchase only the caliper kit (calipers, brackets, and pads) at option and they will mount direct to your OE spindle and rotors just like OE calipers w/o any modification for an instant improvement to your braking performance.
Better yet is your brake bias remains the same as OE with the benefit for:
- A firmer pedal feel and braking confidence.
- Lower the maintenance in pad and rotor replacement.
- Pad inspection and replacement just a breeze.
- Switch back to stock caliper whenever you like.
W
Warren-RB
SoCal
W
Warren-RB
SoCal
Some key features of RB kit may help Raptor owners do their research and find out from the vender, before making a decision.
1. Balanced brake system with same brake bias as OE (F/R: 67/33%)
2. Forged aluminum alloy body, light weight yet stiff and strong.
3. Calipers are built with the same standard as for track racing; with internal dust seal, cross-over tubes, and radial mount.
4. Kit components are 100% iinterchangeable & compatible with stock allowing you to swap between stock and RB kit.
5. Super easy bolt-on installation w/o modifications.
6. Brake pads are standard FMSI shape - Easy to find replacement at low cost.
W
Warren-RB
SoCal
When you buy a brake kit, the critical components and the majority of your investment is on the Calipers.
Why RB is the most experienced and trusted brake company on brake calipers?
1. The knowledge - A collection of 260+ OE calipers (Brembo, AP, Advics, Akebono etc.) on hand.
2. We offer the most comprehensive caliper rebuild program in the performance industry.
3. Helping track enthusiasts with their brake issue on a daily basis.
95,769
59,449
slostjoe
