Robtor310
Interested in group buy, where do I find this facebook page?
Yea me too, dont have Facebook but Ill find someone that does
Posted some more photos and details on the radio mount and install here at this link.
Thanks David, love that distribution block.
2 meter antenna?
KX9ROB
Yea I still have to work up a bracket of some sort for the block, the block
is just tie-wrapped down but working very well. I have not
seen a 3rd party option yet. The Block makes it easy.
That is a dual band 2M/70cm antenna - I switched out the Comet in the photos to a new
Diamond SG7500NMO - has a tilt over base - now in tight garages I can just
fold it over VS taking it off the NMO mount. Seems to be all working well.
Not sure. That is not my picture/truck.I have this same mount. I have not installed it yet since I have not figured out where I will run the cable to get to the center console. How did you run the cable to the center console? What is the best way to get it there?
Im interested in the group buy....where exactly do I reply to?
I just requested to join the group
---------- Post added at 11:54 AM ---------- Previous post was at 11:54 AM ----------
I need to get my antenna mount pretty quickly, put my radio in last night, so it's time for the antenna
---------- Post added at 11:56 AM ---------- Previous post was at 11:54 AM ----------
Ive got an ICOM 880 and I was thinking of putting the face in the sunglasses holder. Not exactly sure yet.
I wish my kenwood faceplate was small enough to put there.
With some help I found a good spot to run coax into the cab. First you have to release the rear seat behind the driver seat. I have not found great descriptions of this so here is another picture of the release. The pin with the zip tie (added) is what you are looking for. A wrench can be used to pull it up. It is a fairly tight space in a SCAB. Note: The zip tie actually did not work because it interfered with the mechanism.
You do have to pull off a fair amount of paneling.
A close up of the gromet. Running wire through here lets you get to the top of the wheel and then it's an easy run to the rear stake pocket.
