Race Radio Installed in Center Console
BigJ
I popped on a couple different ham radio forums to try and learn whats what. It sounds like there is no set channel to frequency map. When you buy a radio like the iCom F3011 for example, there are no frequencies set. You need to either have a radio store set it for you, or you need to also purchase the software and programming cable. Either way, you decide what frequency channel 1 is, channel 2 is and so on.
'tizzle, is that how your Vertex works? Do you use a standard frequency when 'out there'? Kind of like a set it and forget it type deal? Or do you change on the fly depending on who you're grouped with and the frequencies they're using?
Raptizzle
Raptizzle
FYT
Southern CA
I had mine pre-loaded with the Baker MS frequency and some of the major race teams so you can listen in when you're at the races. I still don't know if I can get the typical VHF numerical channels. I'll get it figured out and will report back.
BigJ
Thanks!
PS: What's a "Baker MS frequency"? I know I know, I'm such a newbie :D
Raptizzle
Raptizzle
FYT
Southern CA
Baker Motorsports is the shop who built (modded) the truck. I'll be running quite a bit in Baker's trophy truck in the near future. :D
Stepside
Looks good. Sorry, i'm new to this whole off road thing...what is the benefit of a CB over a VHF radio? Should you have both when off roading?
So if I want a CB, what do I need to look for? What strength is sufficient? Will a $50 Cobra do the job?
Unless you run illegal power on CB, there is no benefit.
CB - is HF (high frequency); 11 meters; AM - amplitude modulation
150+ MHz is - VHF (very high frequency); just above 2meters; FM - frequency modulation;
clearer sound. not sure about FCC license required.
FRS - no license; 1/2 watt max; UHF (ultra high frequency); just above 70cm band
GMRS - license required; more power; just above 70cm band, works sometimes with repeaters for extended range.
Both these signals reflect well off objects.
Or you could take a Test to get your Amateur Radio License aka HAM Radio.
Technician Class = limited HF/ full - VHF/UHF privileges - range 50+ miles
General Class = most HF/ full - VHF/UHF priviledges - range = around the world.
Extra Class = full HF/VHF/UHF priviledges - range - see above
When I took my test I had to learn Morse Code
This is No longer required.
Two weeks of study -- get your Tech license
Most all HAMs Do Not engage in foul language "ON THE AIR"
BigJ
Its even easier than that these days. My wife and I didn't study a lick, and instead went to a 4hr class where you learn everything you need to know, and then immediately take the test.
If you plan to spend any time in the wild, IMHO there's no reason not to get your ham and choose a dual band radio. Its not only a way to stay in contact with your buds, but its an emergency device too; there are very few areas in the US these days not covered by a mobile station reachable active or monitored repeater.
