GEN 2 R1 bbk
FmaxTurboSi
So Cal
very nice...... let's see some pics of the entire truck now.
Yes sir!
Bed them in this morning and so far they are outstanding.
Going to bleed them again and make sure all the air is out of the system.
brettmess24
brettmess24
H o l e y s h * t !
I just finished running 2 new liters of Dot4 fluid through the system with my motive bleeder and had the lil ****** pump with the truck on.
Absolutely had air in the line or master as this truck now stops like I hoped for! Hold on!!!! The Ridge Grapplers Sounds like a jet landing and grip pretty damn good.
All corners come in aprox. 8lbs less with 3 lbs being rotating mass in the rotors. 380mm F w 8 piston caliper. 356mm R w 6 piston rear caliper.
Stock set up does not weigh 230lbs I measured aprox. 192 lbs w/8k miles.
Waiting a bit before leveling the front to see how much the deaver +2HD with Camburg shackles settles. It’s currently at 41.5” in the rear w/100 extra pounds. Front is 39.75”.
